Claus skrev: - samtidig har skiven en rigtig stor indflydelse om gasdampene som opstår i friktionen mellem belægning og skive om de kan komme væk eller om de ligger som en "hinde" og gør bremserne svampede i pedalen.
Den skal så lige udfordres
Adherents of gas emission have carried that belief to motorcycles, bicycles and "sports" cars, while all other disk brake users from the same automotive companies have no holes through the faces of their discs, although internal radial air passages are used. Vents to release gas have not been found on railway, aircraft and passenger car brakes because there is no gas to vent. Meanwhile heavy trucks still use drum brakes because they offer more heat dissipation than disks that would fit in the same space. Railways have never used internal expanding drum brakes because they cause skidding, causing expensive flat spots on steel wheels."
Link til siden: http://en.wikipedia.org/wiki/Brake_fade
Og også denne: http://en.wikipedia.org/wiki/Disc_brake
